Ever wake up in the morning and realize that you left your garage door open all night long? It happens to the best of us. Here's how to setup InControl to send you an email reminder when you've left it open past 9 PM.
In my setup, I use a standard door/window sensor for one garage door and a tilt sensor for the other. The setup for the tilt sensor is much easier than the door/window sensor because it can simply be mounted directly to the door -- on the other hand, I had to build a fancy mount for the door/window sensor.
My garage door is also far enough away from my other z-wave devices that I would occasionally miss an update from the sensor. To remedy this, I purchased a few z-wave repeaters to plugin to a few outlets to beef up the range in that area.
That's it! You will now get a message if your garage door is open past 9 PM.
