The multi-user security plugin for Axial Server is designed to allow you to control which devices and scenes are controllable from each of the mobile phones connecting to your system.
Once setup, each of your smart devices is able to control a specific set of devices and scenes. This tutorial will guide you through the setup process.
To confirm the install was a success, start Axial Server and go to Plugins/Multi-User Security/Setup Multi-UserSecurity. You should have a screen that looks like this:
Be sure to check the box that says "Enable Advanced Security" to turn on the plugin.
At this point, you'll be creating a new password for each set of scenes and devices you wish to secure. For example, if you wish to allow a house guest to have control of a light and outlet in the guest bedroom, you'd create a new password for that house guest and then input the password in the Axial Mobile app running on the smart phone.
When you add a new password, the following options are available:
To setup a password to only be able to control a certain set of devices or scenes, add them to the list as appropriate. The following example is used to allow kids access to a handful of devices and a single scene.
